Subs aren't hitting like they should... Please Help
You can set the gain on the amp with whatever sub setting you want. It really doesn't make a difference (as long as the signal being sent to the amp is not clipped). You have more range if you set the gain with the subwoofer volume up, as you can attenuate it down as much as you need to. For instance my kenwood clips at 33/35 with
+13 subwoofer setting. If you bump it to +15 (max) it clips at 29/35. I can choose to set the gain at either point, knowing exactly where I cannot go past either way.
I should say this is also h/u dependent. If your subwoofer volume control boosts certain frequencies, it is best left at 0.
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
392
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
493
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
659
heimsothe
heimsothe
Portland, OR
nismos14
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
