Pyramid x 702 wiring information, diagram/manual needed
72cutlass
Junior Member
ohio
Hi, I was just given a Pyramid x702-L 300 wat amp/eq. It is old school, and there is no manual or wiring diagram that came with it.
Besides the red+ and black- there are 9 other wires.
white,yellow,orange,purple, (these go into fader)
brown, green,blue,gray, black, (go to 18 pin block which also has power switch)
Apparently it does not follow standard wire code,
Does anyone have any idea how to wire this?
I agree with the above comment. Those EQ's have built in power, but it is going to be less than modern head unit power output. Probably a better idea to just leave well enough alone, it will only make things sound worse.
Hi, I was just given a Pyramid x702-L 300 wat amp/eq. It is old school, and there is no manual or wiring diagram that came with it.Besides the red+ and black- there are 9 other wires.
I am trying to put this in a classic car and want to keep it era correct with the old school cassette head unit. I realize it isn't going to sound like the modern units I have installed.
I have 7 of these units brand new old stock for sale
From my collection a Pyramid PB401a amplifier from 1986. Class AB amp claims 100 watts per channel. Bridgeable and has separate gain control for...
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
107
362
356
72cutlass
Junior Member
72cutlass
ohio
alan Freeman
    May 18, 2024
    May 16, 2024
