Dayton Ultimax 12" vs. IDQ12 V.4 2Ohm
Are you set on those two choices, or are you open to suggestions? What amp will you be using, how much are you wanting to spend, and do you already have a box or will you be building to suit the sub?
Well i just bought the IDQ12 V.4 D2. Paired with a Rockforod fosgate 1200W amp. I want to build a box but dont have time right now since im moving in 1 week. A pro audio store said they'd build one for around $400. That seems steep though...
I personally think that's a solid combo. No, not the best, but far from the worst. $400 is about right bro. Designing a correct box is one thing but building one is easy. If I were you, I would pay the small fee to get someone here to design a box for you and then go to work building my own box.
It was around $450 dollars for the sub and amp. Outta curiosity what do you think would've been better?
for the $ u did good.. can't believe they want $400 for a single 12 box that's crazy guy here got one with kerfed port for lots less and that was shipped.. oh it was anthony., i'll try to find the name of company for u..
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
BroncosNeverDie
Washington
BOOMINGRANDPA
    May 16, 2024
    May 16, 2024
