Need subwoofer/amplifier/enclosure selection help!
RadioShackSQ
Hello folks! I'm currently putting together a modest SQ build and have run into a bit of a snag with subwoofer, enclosure, and amplifier selection and would greatly appreciate some advice on the matter. The snag is my lack of familiarity with the current "good brands" and the strange lack of shops willing to demo SQ subwoofers or their "high end" subwoofers. While the overall goal is excellent sound quality, I am an oldschool basshead at heart and still want exceptional levels of loud when the mood strikes me. I have, over a few decades, owned various sizes of subwoofers and enclosures and have found that they all have their own merrits however, my favorite subs/enclosure were 2 Soundstream SS10R's (circa mid nineties) sealed with a 600w monoblock supplying the juice. I would love to have something that either matches the level of output and accuracy of that set up or exceeds it, in terms of sonic transparency, as well as the ability to compliment my front stage set up and rattle some door parts loose. I have access to Arc Audio, Hertz, Focal, FI, DD, DA, JL, Audio Frog, Sun Down, and Fosgate.  I would prefer to stay within a budget of $1500 for sub(s) and amplifier. The environment is a 2018 Mustang GT, and I have, roughly 3 cubic feet to use for enclosure space. The build, so far, is as follows:
•Hertz Mille pro 163.3 three way front stage fully active.
•Arc Audio XDi 1200.6
•Arc Audio PS8 DSP
Any help would be greatly appreciated!
The max box dimensions you can get in that car are 32 wide, 13 high and about 24 deep. My girlfriend has a 17 Mustang and I have to load the box through the back seats. A pair of 10s with a rear firing port or a pair of 12s with a side firing port is about the most cone area you'll be able to squeeze in there.
Thanks for the reply. I had pretty much settled on either a pair of 10's or 12's and was lookong for recommendations on brand, product line, and enclosure type. I am open to glassing in the areas behind the rear wheel wells too, if it comes down to it.
I put a pair of the Stereo Integrity BM MKVs in my 2017 and am satisfied with them.  Keeping in mind they are more of an SQ sub and not sheer output.  I chose them to save on weight and also still have a usable trunk.  They also make some pretty badass regular format 12's and 15's that require very small sealed boxes, but will require much more power and twice the enclosure of the BMs.  The regular subs weigh 70 lbs or so while the BMs are around 14 lbs each.  How loud do you want to go and how much power you looking to push?
As far as wattage goes, I'm looking to stay under 1500w and l am less concerned about db's but being somewhere in the ballpark of 125-130 should be easily attainable without overpowering the front stage. Going  a little above or below the 125-130 range is perfectly acceptable but the overall idea is for it to be an SQ setup with a moderate amount of volume. I've settled on the Arc KS 1200.1 for amplification fwiw.
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
259
671
RadioShackSQ
RadioShackSQ
Smaple
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
