Blue top vs Deka marine
kcr357
ft laud
Going into a boat w 2x 500 watts rockford amps, 1 is an AB, the other is D.  Charging system is less than stellar, current wise.  Both batts are group 27 and will be dedicated to the audio.
The Deka flooded battery https://www.nationwide-battery.com/deka/27m6.php actually has better specs, costs around 130.
The optima https://shop.advanceautoparts.com/p/optima-blue-top-marine-battery-group-size-27m-800-cca-d27m/16940024-P?searchTerm=group+27
has a much better rep, thinking I can get it for a bit under 200.
Are the bluetops going to be worth it, especially having worse specs?  Seems everyone has a hard on for optima, not sure why.
No one has a hard on for Optima that actually know anything about batteries.
Dont waste your money on Optima. If you have a sams club membership their Energizer AGMs are really good and not expensive. The group 31s are $179.
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
You've read an outdated book...most of us learned things by either trial and error or someone more experienced helping...not a 20+ years old book 🤣🤣🤣
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
kcr357
kcr357
ft laud
BOOMINGRANDPA
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
