Voltage to amp
1500 audiopipe mono block amp
15 inch Rockville k9 run at 1 ohm
What should voltage to amp be at I have multimeter
if the car is running, youre going to want to see around 14.4 volts, if its off, 12.4. Bear in mind that you will lose some voltage over a length of cable, but the loss shouldnt be too much. Just do yourself a favor and get a voltage meter like this one  and connect it to the positive terminal of your amp and put the display up by your deck. Calibrate it and you should never see below 12 volts on that meter when banging or youre risking damage to your amp
let's take an exemple :
Hmm, lets see what we'd need for .1 second of discharge. V(t) = V0 * e^(-t/RC) C = - t / (R * ln (V(t) / V0)) C = -.1 / (.003 * ln(3/6)) C = 48 Farads Now a cap that large would need the ESR/ESL factored in as well, and hopefully the electrolyte wouldn't get cooked out from the heat of discharge.
Lucky Patcherhttps://inro.in/lucky-patcher/ 9Apps VidMate
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
646
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
It depends on the brand. My JL has 500k Ohms, old Fosgate has 80k Ohms, and old Orion has 80 Ohms. These are the ones I had on hand for testing.
22
4K
Brandon66
Brandon66
slide95
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
