Insulating wiring
Not sure what you mean op.... I've had systems in az (Tucson and Phoenix) since the late 80's and the only heat issues I've had were as a noob.
Undersized wire,  touching exhaust manifold, poor connections... etc
Explain why it's a concern
Depends where the wire is running to and from mate! :suave:
In case of power/ wires from the engine bay which has exposure to heat; :uhoh:
  • use plastic conduit a bit larger then the power cable all the way in side the engine bay, and secure with cable ties; use correct lug connections and ensure the connections are secure;
In case of behind the head unit, speaker wires, and amplifier wires; :furious:
  • ensure you apply solder, followed by heat shrink over to avoid short circuits; behind radio and to speaker terminals; use at least 14 - 16 gauge wire for installations;
  • use cable ties to tidy up wires behind the head unit so that wires and RCA's are all neat and secure;
  • ensure you use correct size power / ground distribution blocks from the battery to the amplifier(s);
  • ensure that all connections are safe during installation and no frayed wire is touching the other terminal;
  • check correct speaker / subwoofer connection to the speakers and the subwoofer input terminals;
  • check subwoofer input terminal to confirm strong connection;
  • secure your subwoofer box in the trunk area so that it does not move and hit your amplifier which could cause wires / ground to loosen;
  • remember, power travels from negative to positive, hence the 12v negative ground theory so make sure you have good grounding point;
Hope some of this suggestions are helpful in your case. :suave:
Cheers!
In my last 2 vehicles, the decks both had wiring issues. They would be fine for about a year, then randomly play on either the left side or right side. Only after about an hour or so would both left and right sides of the car play together. Maybe I should have labeled this as a deck wiring issue?
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
225
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
631
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
665
659
564
Warpshift
Junior Member
Warpshift
Tucson, AZ
Warpshift
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
