Will I still get a sundown x 12 to flex with a JL 600.1v3?
  • 5
Whoanow916
I know the sundown x12 is 1500rms. I been using a jl12w7 which is 750Rms with a jL600.1v3. i totally understand I'm under powering but eventually I want to upgrade the amp to jl hd1200.1 and alternator but not anytime soon. I'm just tired off my w7 and want spl.
I was wondering is there going to be a problem with the amp I have and sub I want (sundown x 12)? Will I get good spl with a JL slash 600.1v3 with sundown x12? Also should I go for 4ohms or 2ohms subwoofer?
Spl is not flex. "Flex" is just visual panel resonance. Flexing panels does not mean loud, as a matter of fact flexing panels are a source of lost output. Panels that flex are just thin flimsy sheetmetal panels with a low resonance point.
Out of pure curiosity, why dont you just re-enclose the 12W7?
I bet with a new box and some power added it'll do fine... I mean... jeez... you paid for it already
Well I had the 12w7 for over 12 years and it's been in all different types of boxes including a HO box. I guess I'm just tired of SQL. I need something to give me a massage. Maybe someone can send me a link to adjust my amplifier to the correct settings.
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
added a 32AH bank to my system...... Cot damn! Now we rockin. Voltage staying above 13 wide open!! Just thought I'd update.
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
Whoanow916
Whoanow916
Sacramento
Whoanow916
    May 31, 2024
