Kenwood upgrade from factory wiring question.
tekfire07
I am considering upgrading my factory radio in my 07 Chrysler Town and Country with the Infinity sound system. I am reading conflicting information regarding the stereo install. Could someone possibly clear up the information for me?
I want to upgrade to the Kenwood DNX696S with XM,CMOS-230 and DRV-N520 camera's. i also want to retain the factory steering wheel controls.
My confusion comes with the factory amp. Do I have to by pass it? I would like to retain it, if possible. I am completely happy with the speakers. Some people tell me I have to by pass it or install a after market amp. I have also read it is recommended to upgrade to after market speakers. if you by pass the amp, to prevent burning out the speakers.
Hopefully someone can clear this up for me.
Thanks in advance for your time and any help you can provide.
Erik C.
Erik C.
Why would you have to bypass it. The amp is already connected to the speakers. All you need is a remote wire.
Erik C.
Have you considered:
  • PAC ROEM-CHR Chrysler Radio Replacement Interface w/ Infinity Sound System
  • SKU: PAC13-ROEM-CHR
  • Plugin installation retains factory wiring integrity
  • Transformer isolated for optimal sound and performance
  • Maintains correct phasing
  • Retains the function of the factory-installed amplified sound system
Not sure about the steering wheel control interface. Might want to contact them for more info.
https://catalog.pac-audio.com/catalog/radio-replacement/swi-rc
So if I understand what you are saying correctly. All I need to do is connect the Kenwood harness into my factory harness and then run the blue and white wire to my factory amp. Is this correct? My van has six speakers that are 2 ohm. Crutchfield says that I have to bypass the amp because the head unit is 4 ohms and can only drive 4 speakers. So I need to bypass the amp and then install 4 new speakers and replace the 2 dash speakers with 1inch tweeters. I am so confused as to what is correct. I have installed several car stereos. But I have never done anything with Amplifiers. I hope someone can help me out.
So with upgrading to a new head unit you will need obviously the corresponding wiring harness. The amplifier has a ground, power and remote wire. The existing wiring going to your stock unit should have the wire already there so when you switch out the harness you will connect the remote to the new line (blue and white)
Thank for the help. That's what I was thinking. But the more I researched it. The more I got confused.
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
651
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
893
tekfire07
tekfire07
S E Michig3
tekfire07
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
