SA 12 Rattle
giltyler
Have a 7 month old SA 12 Chrome back magnet with a non coil related rattle.
Picking up the sub and shaking or just rotating it you can hear something metallic moving around.
coil still looks new and cone moves full travel without and noise
Ohms out 2.2 and 2.3
any ideas what Could be wrong
Wiggle the terminals to see if a spring has become weak. If that is ok, then face sub down on the floor and look into the vent hole. If anything is in there, it should rest on the dust cap center. If something is in there, roll a piece of tape as if about to hang a poster and tape it to the tip of a pencil or straw and operate. Good luck.
Nothing is in the vent or gap. This is under the spider and outside the coil from the sound it makes and is loose but not really floating around.
Does the cooling vent have a screen? If not, maybe something fell in there.
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Example. H.depot or Lowes should have some also? or a hardware store
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Play the system when your muffler is cold and crawl under there and grab shitt until it quits rattling. That is really the only way to fix the...
giltyler
giltyler
DFW METROPLEX
deez283
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
