Better option for the money than DCS165-4?
  • 2
4BangerStanger
117
DFW
I'm looking to build a box for my 2019 F150 crew cab. It'll be going under the rear seat and I want to run 4 6.5" subs. I've always wanted to give Dayton a try and at $40ish each, the DCS165-4 look hard to beat. Are there any others that y'all would recommend for a similar price ($50ish ea). I'll be using my SoundQubed 1200 amp.
In a vehicle environment, you can do a smaller box than what they recommend for it. The recommended size is .5 I think, but you could drop that down to as low as .25 cubes per sub, port tuning at 38-40 hz.
Sweet. The box I planned out is about 1.53 cubes and can go a little bigger if needed.
Do y'all think the Tang Bands would be any better. They're about $14 more per sub. Not too bad.
They are half the wattage as the Dayton’s, but they have more xmax. I have the tang band 5.25 sub in my shop bluetooth stereo, and the 6.5 inch in my home audio system, and they are awesome. i also used their 3 inch sub for my daughters bluetooth build. I’m super impressed by tang band, if you can’t tell. Lol. i just wish they had a higher power 6.5 inch or 8 inch, and I would be running them myself. As it stands, I’m using the Dayton ultimax 8 in my Jeep, and I also wish Dayton would do a 6.5 inch ultimax. It’s a little beast.
OK, so it comes down to it and you're placing an order for 4 subs, based on currently available models, whatcha pickin'?
I would have to choose the daytons. Double the power will get louder, and Dayton’s are just as quality of s product as the tang bands. In home audio, i would go tang band all day.
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
2.5 cubic feet per subwoofer not total. Those X's require some room.
781
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Alpine, and it's not even close. I own that Alpine unit and the 9-band parametric EQ is much more useful than the 5-band graphic on the...
4BangerStanger
4BangerStanger
DFW
SlugButter
    May 18, 2024
    May 18, 2024
