Ltonedesma
I have a
KICKER - CX 360W Class AB Bridgeable Multichannel Amplifier with Variable Crossovers
KICKER - CS Series 6" x 9" 3-Way Car Speakers with Polypropylene Cones 4 Ohms in the rear
Kenwood - 6-1/2" 2-Way Car Speakers with Polypropylene Cones 4 Ohm in the doors
and it was wired by Best Buy, I have a 2006 Pontiac Grand Prix GXP and want the dash speaker to work again since I bought a new speaker for it before I knew they sold me a 4 channel amp and the only wired up 4 speakers. the other speaker for the dash is a Kicker 46CSC354 also a 4 Ohm speaker is there anyway I can wire the speaker from the amp to the dash and have it be safe like add a speaker to a channel even tho it has the 6x9’s or the 6.5’s on it
You could just hook it up to the factory wiring and let the factory amp/HU run it. Otherwise you’d have to wire the dash speaker and a door speaker together for a 2-ohm load, and run that to one channel on the amp, but that’d be difficult since they’re far apart.
I can’t see anything from that attachment
x2, I don't see anything.
OP, the easiest thing to do would be hook it up to your radio. The issue with a center speaker is that you need both left and right side sounds going to it. So if you hook it up to your radio, then it's only going to be left or ride side that it'll be hooked up to.
Hey, I have golf 2019. I have audison voce and want another speakers in front, and the Audison move to the back I have thought about those- Focal...
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
I combine the fuse ratings of both amps and use that at the battery with the appropriate size wire and if an amp doesn have onboard fuses I will...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
4K
Ltonedesma
Ltonedesma
Lansing
Buck
    May 31, 2024
