Need Help Deciding On Sub Purchase
Stronger 12 or Weaker 15
  • Skar SDR15 + Skar RP800.1
    Votes: 1 100.0%
  • Skar SVR12 + Skar 1200.1
    Votes: 0 0.0%
  • Total voters
codyc03
28
Utah
Hello! I am looking into getting my first sub and amp setup. I am thinking about getting a 15 inch skar sub with 600W RMS and 1200W max at 1 ohm and an amp with 800W RMS and 1200W max at 1 ohm. I have never had a setup before and don't know how loud this will be or if it will be enough. I mainly listen to rap and don't need anything insane, just want something to get some nice bass and something that will rattle the trunk a little. Would this be a good setup? Any recommendations?
I appreciate all the positive feedback! I've now added another possible combination into the mix. Between the Skar SDR15 with the Skar RP800.1 or a Skar SVR12 and a Skar RP1200.1, any recommendations or insights? Once again, I'm totally new to this so any feedback is great!
Now that you said hatchback, I know it will sound solid. Even a nice 8" sub sounds good in a hatchback, most settle for a 10" with zero complaints. Now, a 15" in said car will drown out your front stage, which you have heard those cars on the road, all boom no voice. In this case I vote on the 12" setup.
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
140
723
761
codyc03
codyc03
Utah
Firewalker
    May 19, 2024
    May 19, 2024
