15in Sub Sealed under 275 bucks...
  • 6
FineLinePimpin
Stuck in WV
So considering a few subs...under 275 bucks - 2cu or so sealed - gonna be powered with a CAB 22, overkill yes but preparing for more later lol
DC level 2 15 - 240 bucks
Crescendo Forte 15 - 270 bucks
B2 Entry level 15 - 260 bucks
Anything else I should consider? Going in trunk set up.
I didn't know DC made a lvl 2 15. All the other subs would recommend more than 2 cubes sealed.
I think your best bet would be a Dayton audio HO 15.
I would go smaller subwoofer ported personally. Dayton MX 12 ported would be my choice.
x2.
I wouldn't put most DC's in sealed personally. The resonance you get from small box sealed woofers tends to be too high for my tastes. Like dudes who put their 15's in 1 or 1.5 cubes sealed and wonder why the have no lows in a 4th order lol. Idk, maybe I'm just particular. Sealed boxes are only good when there's ports involved somewhere else lol :geek: 😁
I would do a small box 12 ported, if I could fit it in that space. I would expect it to be quite a bit louder, on the same power, and you will have more lows, if the woofer allows it, and the box is proper.
Getting a good voltage reading does not mean good power transfer. You could read 13.8v out of a 24 AWG wire. Recheck your amplifier's ground and...
198
539
568
FineLinePimpin
Stuck in WV
FineLinePimpin
Bunker Hill, WV
Buck
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
