Audison lrx 2.9 in Protection
  • 6
Mirza54000
Dubai
Hi Guys,
I just bought this Audison lrx 2.9 amplifier. The amp is wired correctly. Trying to run JBL 1220D (2ohms per coil) . Connected the positive to speaker left positive and negative to speaker right negative. Ground is connected to NEGATIVE and Battery to POSITIVE. Switched between mono and stereo modes both. The woofer is mute and amplifier is showing a red protection light. The fuse is showing a green light. And speaker check is showing an orange light.
PLEASE HELP !
https://www.audison.eu/wp-content/uploads/2017/12/p_1315389315_audison_LRx2_9_tech_EN.pdf
I think I would definitely check the subwoofer wiring first. It seems like the amp may be protecting itself, in relation to the woofer.
How does the amp act when you disconnect the sub?
And I'm not familiar with this amp, you're just going to have to trouble shoot this issue until you find the problem. It may be a simple thing, hopefully.
You will need to jump - from one coil to + on the other coil to connect the two coils of your DVC sub. Google search how to "Series" a DVC woofer.
This should not be putting your amp into protect though so you may have something else going on.
You running a dual 2 ohm sub
Final load being 1 ohm
Amp specs
2x260/ 1x900 @ 4ohms
2 x 450 @ 2ohms
The amp is only good down to 4 ohms when bridged
Un bridge it
Run one voice coil in to the left channel and the other one into the right channel
That will give you the 2x450 @ 2ohms
Considering its only a 300 watt sub this should be more than enough
Even when the subwoofer is disconnected and only ground , remote and battery is connected, the amplifier is still in protect mode
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
Yes mate I have these in a 3 way active front stage and they sound great, have them crossed at 5k, see my recent post for full breakdown of kit I...
Mirza54000
Mirza54000
Dubai
Mirza54000
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
