Major problems with Iraggi Alternator that was damaged during transit.
do you now package and ship and insure correctly?
Yes we do. We put the alternator wrapped in heavy duty wrapping paper and or bubble wrap into a small box, then we put it into a 12x12x12 box and surround it with peanuts to ensure it doesn't move around. We also now cover alternators that are lost by USPS, or lost in transit and will build a new one for the customer if that happens.
  • How To Ship An Alt. English.pdf
You need to troubleshoot. I assume you have an aftermarket HU. I'd start there by running a signal from a phone or ipod (etc) to the RCA outputs...
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
934
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
868
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
SkwurlyFab
SkwurlyFab
SD
Slo_Ride
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
