I'm in search of a purely loud and sound quality system. subs wise.
NOTE: I have plenty of clean power to run around 7k rms in bass alone. 320amp alt charging @14.8. 3/0 royal excelene welding cable and 80ah yinglong cells.
my subs I currently have.
-5 resilient sounds gold 8's. BRAND NEW
- 2 re audio xxx12's BRAND NEW
-2 nemesis hectic 15's
my delima is should I run the 5 8's or the 2 12's?
getting rid of the 15's they sound like garbage. I'm not sure what setup to use. don't wanna start using new subs if they aren't what I'm going for.
I was thinking of saleing all subs and going with 3 fi audio neo 3x 12's and keep it 2 spiders for sq. and the entry level.
I would like to hit somewhere around 145-db maybe slighlty more. again want to have a sq system that can get loud and low like the re xxx12's that everyone says. really wanna try mine.
I'm going to build custom boxes ofcourse and can build quality ones. so not worried about box in anyway. this is purely a sub issue.
NOTE 2: mids and highs are fine. deafbonce mids. the 300watt rms 6.5 ones that play from 120hz-12khz. then tweets are the ds18 4 inch that play from 2.5khz-22khz or something like that. they are plenty loud and clear.
thank you for any help.
