What could be the issue?
Bryant11
Hi I bought the TDA7498 amp and using that wiht my blaupunkt 4ohm speakers. the bass reduces as soon as o connect the 2nd rca. if i use the speakers on the same speaker port, the bass is good. its same with other port as well. As long as i am using same speaker out for both the speakers, i get good bass. What could be the issue? Thanks in advance.
Try reversing the wires on one of the speakers. Datasheet shows it as two mono amps. They may not have maintained absolute polarity in some way when manufacturing.
Can you give us a diagram of what you are doing with the amp?
Getting a good voltage reading does not mean good power transfer. You could read 13.8v out of a 24 AWG wire. Recheck your amplifier's ground and...
220
They managed to turn Covid into a wedge issue.
A problem may be caused by your phone's or vehicle infotainment systems' software. Be sure you have the latest software version for your phone and...
I do copy music off youtube, but I've been using audacity. That one's free, and lets you alter the music from changing the EQ, and adding...
Bryant11
Bryant11
Hong Kong
RobGMN
