What can my stock 90 amp alternator power?
I mean really you could get any wattage subwoofers or amps. But it takes power to make power.
I wouldn't personally recommend over 1200 watts rms with the big 3 and a decent front battery.
I had a 99 Honda CRV that had a 90 amp alt. I removed air box and put an air intake in place for room to add an Orileys AGM 34/78 battery there under the hood, added another in the rear, Did the Big 3 in 2ga OFC and supply and ground. MMats HC300D @1750 rms @2ohms on a pair of S.Qubed HDS310s in 4.0@32htz before displacement,One Crossfire 100.2 on a pair of Infinity Kappa 60.9cs mids and CDT DRT-25 tweeters, and one Alpine 3540 Duo-B amplifier on a pair of Hertz 6.5 165 Coax in rears with a Kenwood KDC BT558 U HU with a Kicker KQ-9 EQ. Did very well. I had keep gains down to keep Roof from Rippling so much. But if you do your supply for the demand correctly, you can have a decent system and really nice results. Like Ive always said.. It takes power to make power. Sit down and plan out your system and your supply needs
898
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
729
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
584
BrandonBoy
BrandonBoy
Oakland
ThxOne
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
