Kicker CVX Set up
Which is the overall better setup?
  • 1st setup
    Votes: 0 0.0%
  • 2nd setup
    Votes: 0 0.0%
  • Total voters
  • 2
bryanarriaga67
Texas
Hi everyone, I need a bit of help deciding what sounds system to upgrade to. Im currently running 1 Kicker CVR (350 rms) but I want to upgrade to one of the following 2 set ups:
*2 CVX 10’s(600rms each) with CXA1200 amp
Or
*2 CVX 12’s (750rms) with CXA1800 amp
I’m wondering if the latter setup would be underpowered for the amp or if the first set up is an overall better set up
Use the rest of the money on a custom box and electrical upgrades.
906
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
bryanarriaga67
bryanarriaga67
Texas
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
