Birch enclosures stain color and finish??
Wesseat
I am waiting for a gp audio, custom enclosure to be made.. Im thinking i want to stain the birch a dark gray color and give it a matte clear Polycrylic finish.. Minwax has a Semi-Transparent stain color Carbonite that i think would look good. I found a soundqubed box with a color that i like.. Ill attach a pic. Was wondering what colors and finishes you guys have used on your birch boxes? Attach photos!! Does anybody know what stain and finish soundcubed used on this box?
Mine looks different when I put gloss, but it looks similar before to the sounqube. Pics before gloss are in the thread below. I think I used ebony stain from minwax mixed with early American to lighten it a bit. With no gloss I would have went lighter. I've done alot of different colored stains on birch. This one wasn't my favorite
I haven’t used birch but I’ve been staining with a black/ebony stain and really like the results. I haven’t used any sealer/poly though.
I have 1800 watts and 2 alpine x subs sealed at factory specs now.. Upgrading to 3600 watts and four x-w10d4 's in a 7+ cubic foot birch box tuned to 35hz... I can wait to get it all installed!!
I am waiting for a gp audio, custom enclosure to be made.. Im thinking i want to stain the birch a dark gray color and give it a matte clear Polycrylic finish.. Minwax has a Semi-Transparent stain color Carbonite that i think would look good. I found a soundqubed box with a color that i like.. Ill attach a pic. Was wondering what colors and finishes you guys have used on your birch boxes? Attach photos!! Does anybody know what stain and finish soundcubed used on this box? View attachment 36955
That looks like a black stain to me. Probably just a couple coats or maybe just one to keep some of the wood hue.
38138
I think when they did my box it was done in black paint then purple splashes all over it to match the dust cone colors. I can send you a pic via pm if need be. And it was done in 1" Russian Birch if that matters for the materials. But @Buck would know for sure if it was black paint or black stain since it was his box builder that did the all the work.
On my underseat enclosure I went with Unicorn Spit Red Pepper then took the edges down and light sand for a distressed rat roddish feel. Other enclosure is blue from Next Level Fabrications.
17 layers and it's worth it. Get the Russian stuff if you can. $206 per sheet in Vegas these days.
25
5K
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
Wesseat
Wesseat
Missouri
TheRadio
    May 8, 2024
    May 8, 2024
