Kenwood Owner's/Instruction Manual Needed!
So the video was not of your speakers? Your speakers have just 4 wires and not 5 like in the video? If that is the case, you can use a 9 volt battery and tap it into each pair of wires. It will not damage the speakers or the light display. If the speaker moves out, the wire on the Positive side of the battery will be the Speaker's Positive.
No, the video wasn't of my speakers. It was one I found on YouTube. I've attached a photo of my speakers so that you can see the wiring color scheme.
38318
If I had to take a guess, I'd assume the blade terminals are for the speaker. Most supplied speaker wire uses this blade method. Try the 9v battery test, a 1.5v battery may work as well but I have never tried it.
Edit: I just saw that old school Pioneer uses bullet connectors quite a bit.
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
639
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
883
Vince
Vince
USA
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
