Something new
KicktheSDbasshead
2 builds 2 feet
Super beast 96 ah and a few super caps for the impala took the deaf bonce out and am trying the sundown xs for the first time. Kept the deaf bonce apocalypse 6k thiugh
From what I've seen and heard the Deaf Bonce Koreans are good. The Aab line is questionable.
if I’m not mistaken, the AAb amps are pretty much the soundqubed U1 line. I was seriously considering running an AAB 7900.1 but decided to just stick with taramps. Not a fan personally of the ningbo build house.
Those MD8000's and MD12000's seem to be very good amps with the right electrical.
im going to run the smart series, the smart 5k. For the interior speakers gonna do the Ds1200x4. I have a 320 amp alternator along with a Xs power d5100r agm under the hood and an Xs power xp2000 in the trunk. Debating adding a super cap bank, already made the holder for it. I do have a back up where I can add more batteries if needed in the spare tire well hidden.
If you stay between 12v and 15v then you will be golden.
if I see 12’s on the voltage gauge, I will pull over immediately and get more batteries 😂. I’m tempted to pull the trigger on a bank but I’m old school. Back in the days all the caps did nothing and I never even bothered with them. Seeing all these 500F or bigger banks got my attention but not enough to play with them yet. This setup I think would be perfect to give them a try but would rather do it after some play time to see if and what the difference is.
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
KicktheSDbasshead
2 builds 2 feet
KicktheSDbasshead
San Diego
KicktheSDbasshead
    May 18, 2024
    May 18, 2024
