Low volume Aux-In
Bartass72
Poland
Hi, is there any solution to solve this problem, difference between USB volume and aux-in is 20 points. My deck is Pioneer mvh-s310bt and Samsung galaxy A52s 5g. Same thing with Bluetooth. I've tried headphone dac too, but car stereo unit doesn't see it. Anyone was successful with it, what you suggest I should do?
Bartek
See if your radio has this option.
I ended up Reseting my HU and Mirrioring my Blutooth from HU to Phone again and it worked just fine afterwards. Kenwood HU
I did it before. No success. When I had rooted Xiaomi Redmi Note 4, with Viper4Android, sound on Bluetooth was loud. Unfortunately I don't have plans to root Samsung - Knox, Updates, NFC, etc.
I think i solved the problem, downloaded Bass Booster app from Google Play Store,and set volume to 100%,set equalizer on the app on flat, together with Wavelet, and HU audio settings all plays good and loud by far. Didn't notice any distortion or lag.
Thanks for the response back of the issue. This will help others. (y)
what ^ said. amp gain setting info, test tones are at the very bottom...
471
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
i did end up getting the amp and subs you suggested, looking forward to hearing what it sounds like as soon as the stuff gets here and the weather...
43
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
631
Bartass72
Bartass72
Poland
Bartass72
    May 22, 2024
    May 22, 2024
