4 gauge or 0 gauge ofc
Jimg
217
13
Not building a big system and will probably not upgrade to any more power in the future.
my question will 4 gauge ofc be large enough to run a 600w mono amp at 2 ohms
along with a 100watt X4 amp at 4 ohms per channel.
length of power wire going to the distribution block from the battery will probably be 15 feet.
Not advice just actually a question.
Why not do 0 gauge ofc just to be safe either way?
Is there any situation that having 0 gauge when you only need 4 gauge would be a disadvantage?
I'm sorry for posting a question on your question but I got kind of curious when reading your post.
reason for not going 0 gauge if it is not needed
truck is a 2016 toyota tundra
the best entry through the firewall fits a 4 gauge wire tight. Don’t know if a 0g will fit through the spot I am looking to use.
2nd reason. I used 0g on the mustang and camaro and the wire is a little harder to work with.
Not a bad kit here.May need a Dual Distro Fused block @ the amps.
Id recommend doing the Big 3. Not a bad kit with the Big3 included
Gotcha. Go with what the truck gives you. I agree with you I was asking for technical reasons. I'd do the same if I were you.
audio legion also has it on their site as well.
Nice Find!!
Nice Find!!
Might just pick up a set or 2 just because
LOL. I was thinking the same. Be good for some short runs to a couple amps for me.The 1/0 kit doesnt look too bad either.I picked up the EQ, but havent hooked it up yet. Looks nicely built for the $
Jimg
Jimg
spokey9
    May 19, 2024
    May 19, 2024
