RCA Y Splitter Off Head Unit or Right Before Amplifiers?
Here2LearnThings
USA
Hi. I am planning out wiring for my system. I have a Pioneer head unit with Network Mode (high, mid, low RCA outputs). I am planning on running midbass and subwoofer amplifiers off the "low" output. The amplifiers do not have RCA outputs, just inputs. Which would be better:
1. Y adapter (one male to two female) on head unit "low" output, then two pairs of RCA wires ran to the back to the two amps
2. one pair of RCA wires to the back, then a Y adapter (one female to two male)
Thank you.
Yes, tweeters, midranges, midbasses and a subwoofer. The head unit will be used to low-pass at 250Hz and below for the "low". The midbass amp (Alpine MRV-T500) and subwoofer amp (Alpine MRV-1000) have built-in crossovers. Midbass will be high passed and the subwoofer amp low-passed.
Thank you.
Yes, they can be set to "Standard Mode" (front,rear,sub) or Network Mode (high,mid, low). It crosses over at various frequencies and slopes. The high is high passed. The mid is bandpassed. The "low" is low passed.
Run one of these.
If you use the crossover in the head unit, then you aren't sending that part of the signal to the amp. (Whether or not that allows a more narrow...
994
No make or model number on it? Do you have an exact picture of the rear and all its glory?
867
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
897
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
756
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
848
Here2LearnThings
Here2LearnThings
USA
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
