heat sink on Club A754
rexbd
I need to mount the amp vertically. I am double checking, I assume the heat sink is the side with ridges which is opposite the side with all the connection points. Therefore I would mount the amp with the connection side pointing down and the ridges pointing up. Correct?
Assuming you have room for air flow it should not matter which direction the amp is mounted.
I would not recommend mounting the amplifier upside down, like under the trunk deck. Heat rises,and excessive heat isnt good for any amplifier honestly.
Upside down should be fine. Airflow is all that matters. My buddy did this install. I think 14 amps. Look at that sloppy wiring. 😂 Vegas don't play.
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
Are there any label making machines available that allow you to print directly on your currently owned heat shrink and not from a manufacturer...
Any air movement is helpful in keeping any amplifier running cooler as long as there is a way to release the heat build up. I install all my amps...
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
The gto 6.5's is what i put in a friends ride and they sound good.i am running the 6x9's in my truck and love em.they get loud and handle power.my...
rexbd
rexbd
illinois
Bobbytwonames
    May 16, 2024
    May 16, 2024
