Daily 180 Build
  • 6
I know what Carlos does….what I’m saying is it’s different orgs….the guy who did the 185.4 is Rp patel…db drag sealed on the glass ….Carlos does like high 170s sealed on the glass
He's over 5 db different sealed from the glass to the kick? That doesn't sound right.
Not too sure what 165 @ 20hz feels like, but I know 1st hand what 165 @ 35hz on music feels like, and it's brutal .... The Pride Audio Suburban would do 165 plus on 30 sec music average runs ...
That 165 @ 20 hz. was on a 30 second music run.
Yes….ive seen more than a 5 db difference from kick to windshield….the extreme cab builds are purpose built so usually with the center console they build pressure better in the kick vs windshield….unless you build to be aloud at the windshield….hence the reason they stick to USACI orgs and avoid dbdrag….a lot of people don’t like DBdrag cause they score lower which is understandable cause they want to see the bigger number…but it is what it is
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
If you wire it to 1 ohm it will make 15,000W You should expect to pay at least double the MSRP of that amp in electrical upgrades to properly...
Technically I need to have the internal Regulator replaced, but considering it's cheaper to buy an ECU for 350-400, send it to get the immobilizer...
137
19K
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
Bobbytwonames
    May 16, 2024
    May 16, 2024
