2 kicker L7 15s 4th or 6th order enclosure need help!!
Did I put 2 kicker L715 In a 4th order enclosure or 6 order enclosure
  • Total voters
saint0241
So I've been trying to do a 6 order or a 4th order I was Leaning more towards the 4th order But I am stuck on Enclosure dimensions and design I've been trying to do it for a week and a 1/2 now and math was not my Thing. I don't want to put one in a sealed area it's too small or too big . Was hoping somebody could help me So I could understand some of the equations and stuff. Was looking for like a low thirties And mid forties tune to. Any in all help would be greatly appreciated thank you My head can only get smashed against the wall so many more times
Kickers tend to do fairly well in sealed and 4th orders. If math isn’t your thing, I’d definitely not try a series 6th. You can put those L7 15’s in the range of sealed they recommend and that’ll do well for the sealed section of a 4th BP. Kickers tend to do well in larger sealed boxes.
What vehicle and power?
What vehicle are you putting those in? Are you doing it just to do it or are you doing it because you think it is the best approach for heavy bass in your vehicle?
2015 Kia soul and I'm doing it to get the most out of my car. It sounds good but I'm looking at this design.
2015 Kia soul and I'm doing it to get most out of vehicle I was looking into this design .
522
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
saint0241
saint0241
saint0241
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
