Need help on adding a 3rd Sub
  • 2
MP2121
Hello everyone, I'm new here, and I'm fairly new to wiring/installing systems, although I've had em in my cars over the years quite a bit. Currently, I have (2) JL Audio 12W0v3-4's in a ported box, with a JL Audio JD 500/1 then a JBL Stadium 4, 1500 watt(100x4 rms), to power my factory head unit/DSP, my components up front, 6x9's in rear shelf... I'm wanting to add a 3rd sub(same as other 2), and I'd upgrade my amp to the JL Audio JD 1000/1. If I wired them using jumper wires like my 2 ate presently wired tup, would all 3 subs get 600 watts RMS?? Also my alternator is 130 amps, so would I need a high output alternator as well?? Thanks in advance y'all!
Won't really work. You can wire the subs to 1.33ohms, 12 ohms or 6 ohms. You need a 1 ohm stable amp. Or get some 4 ohm DVC subs which could be wired to 2.66ohms.
So you have an 800 watt sub (1600 is a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
89
694
748
970
MP2121
MP2121
Missouri
Jimi77
    May 19, 2024
    May 19, 2024
