RCA's into this amp
flyfishing
I am just a rookie at auto sound so excuse my ignorance. I am used to seeing Left and Right RCA connections into an amp. This amp does not label them like that. This one say Channel 1 2 3 4.
Which RCA's go into which Channels???
Thanks,
Doesn't matter which RCA goes where, as long as the input matches the output. If you put your front left RCA into channel 1 input, you must hook your front left speaker to channel 1 output.
I am just using this JL Audio Blue Tooth Receiver and it has (2) RCA outputs, red and black. I want to run (2) 6x9's and (1) small subwoofer.
If I have (2) RCA outputs what do I need to do to for this speaker configuration?
Thanks,
Thanks,
Plug into channel 1 and 2 and switch the switch to the left of the RCA connectors to 2 channel mode
Thanks,
I've never seen a product like that. Why not just run a bluetooth amp?
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
Glad to hear it was a simple fix and the amp is working again. The 9v reading indicated it was likely a bad connection somewhere.
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
860
flyfishing
flyfishing
Orange County
flyfishing
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
