Maximum Safe Gain
  • 2
tan271234
Romania
Currently my amp gain is around 1-2 o clock and my speakers still sound good without clipping. Which is the maximum gain I should safely go? Havent tried higher yet because I listened enough for today to the 1000hz tone. Also tested with music too and no clipping/distortion.
Nobody can answer this question for sure without being there. Buy a cheap scope ( less than $40 )and answer it for yourself. Also, when you use the scope, disconnect the speakers.
Cant use the scope because the amp is plug and play. Can only set it up by ear. Will I hurt the speakers by playing a 1000hz tone at 75% volume while setting the gain?
There aren't many wires coming off the amp. There's: power in (12V Batt +, usually the big red one), power out (Ground, usually the big black...
Hello, I am getting ready to install my 3000 watt taramps and 2 15s in an expedition. I am a little hung up because my old car had a 220 amp...
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
884
tan271234
tan271234
Romania
tan271234
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
