Kaotic Kustoms subs... pics, and all that fun stuff
The 12" steel basket
12 inch
Voice coil3 inch copper VC D4
RMS800WRMS
MAX power handing1600WMAX
SPL85dB
Cone material Paper
ImpedaneDual 4ohm/
Frequency response35hz-2000Hz
Magnet material Ferrite 140 oz
XMAX26m
Qts0.87
Vas30.95liter
Qes0.98
Fs40hz
42638
42639
42640
This 12" has a 2.5hp (2500 watt rms)
4" copper coil
200 oz motor
fs 32 hz
Qms 4.85
Qes 0.35
Qts 0.32
bl 23.3
vas 35.4L
sd 471.4 cm@
25mm xmax
42684
42685
Single 1 ohm 3" Coil 3.25" wind width (18 awg copper wire)
Shorted this on a 1000 amp battery and takes it like a champ. Do some Big dummy math and it's actually over 10k... I told some kids I took the coil out of there moms vibrator after I banged her. The one ☝ the one lower ones the Gonzo Jizz facer jr. Spooged edition that's close to the ☝ there. Just has a 4 layer 20awg copper coil that's extreme and way better than that aluminum **** they use to save money bc copper electrically more efficient and don't brake when it gets loose butthole and slaps the side 3 times and no longer have 2 coils lol. Dumb **** people believe but cannot except this as truth. It is
What would be your cost savings per unit having your coils wound in aluminum instead of copper? Can you quantify the efficiency (or dB) gains you get with copper over aluminum coils in each of your motors? Are there any other differences in TS parameters you consider when deciding on which material you want for your coils?
225
447
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
605
870
LFR
LFR
Lacey WA
hispls
    May 20, 2024
    May 20, 2024
