I can only get sound out of 2 speakers with a 4 channel amp
Steven Pfarr
I just finished installing a 4 channel amp into my car and I can only get 2 channels to work. I have a skar audio RP-75.4AB 500w amp, and a pioneer s322bt head unit. In addition to that i have a 2 channel amp running a sub. I have been using the head unit to power the 4 door speakers but it did not have the power necessary to do so. It has 2 sets of rcas one for the sub and a second I ran back to the skar amp and split it to hook up to the 4 channels. after doing so the amp would play out of to speakers no matter what configuration i moved the rca inputs to, sometimes it only played out of 1 speaker. The rca output on the head unit is for full range front speakers is that the problem am I not able to split it to run both front and back speakers?
Could I just connect the 2 non working speakers to the working ones?
or would I have to buy a line output converter for the rear set and the run another rca?
Put the RCA’s on channel 1 or A whatever it’s labeled I’m too lazy to look and is there a switch to go from two channels to four channel mode?
Don’t daisy chain speakers like that
Hertz makes good speaks as does Focal. Often times how "open" a system will sound depends on the vehicle's interior. Big wide dash boards tend...
I would pull each speaker and test as well . Check with a DMM and a different HU or? as stated. A 12v battery and an Old HU usually works just fine
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
Steven Pfarr
Steven Pfarr
Wisconsin
Grimmjoww
    May 31, 2024
