Mixing Component and Coax
csmolen
SC
If i were to put midrange woofers in my front doors, and then coax 6.5s in my rear deck, would the tweets on the coaxials make up for the lack of tweets with the midranges up front, or is it recommended to add tweeters w the mids?
I would add tweeters upfront. Having them in the back only will sound dull and boring upfront and you will be missing a lot of detail in the music up front. Tweets are cheep and easy to incorporate up front. What brand of mid/woofer do you have? See if that company offers tweeters. You could simply run wires off the mid/woofers to inline crossovers to the tweeters and call it a day.
Im not sure if this helps or is the correct way but I have 6.5 mids in the front doors and tweets in the pillars I used 2way 6x9s in the rear deck. The frequency levels go down to 55hz in the front and 60hz for the rears. Not a great deal of bass but the clarity is wonderful. Eq, dsp stuff on the hu and ampd using a good 4ch.
3 or 4 way rears get muddled when tweets are in the front. Rear should support not overstep the front stage.
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
909
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
889
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
csmolen
csmolen
SC
2023 LTZ
    May 19, 2024
    May 19, 2024
