Reducer or run new power and ground
Just buy the adapters like the ones below.
https://www.amazon.com/dp/B07JMVLJ74/?tag=caraudiocom-20
Amazon has a few options like that including off-set ones you can get for around 16-20 bucks.
Thank u that is what i was thinking but im some what still new too building and this will be my best build yet its all jl audio so i want too do it properly and i was not sure if that would be too much power running thew too my amp.Thank u for ur help i have looked all over and it was holding up my install bc i wanted too be sure it was done right thank u so much
Bigger power and ground wire using a reducer will actually allow your amplifier to get the power it needs.
Keep the larger wire and use reducers. It won't send any more power than it would with 4g. In the circuit, the amp is not pushing the power it can, the speakers are the load, and they are drawing(/pulling) what they need. The larger wire just reduces the resistance.
You can always use bigger wire than recommended, most people don't because it's costs a little more, and it takes up more physical space, (specifically when you are going through a firewall or some tight area). If you already have it, then NO reason to not use it or downgrade.
I would recommend placing Heat shrink at the Min. on the Power wire on the exposed portion of that reducer so its not exposed to a future short out. Thats 12+v exposed right there. Ground that,and it may weld itself to the Amp chassis, and even blow the amplifier supply circuit.
I know that even though a amp only has 4awg inputs.it does make a difference running big cable from battery and split close to amp.should be standard coming from batt, 1 or 0 gauge.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
tjbanik74
tjbanik74
car audio
Bass Addict
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
