Buzz/static from speakers
DarthWitten
Hello all.
My system has recently developed an annoying issue. I installed a Jensen CMN8620 into my 2013 Nissan Sentra (6 speaker non-Bose sound system) almost 2 years ago. Up until now, it has worked perfectly. Recently though, after 5-10 minutes there is a terrible screech/buzz/static from the speakers. I can mute the sound for 60 seconds and then it will be fine for another 5 minutes. It sounds like it is coming from all of the speakers. I changed the balance to see if it was just one or two of the speakers. But it is coming from all of them. The right side is worse though.
I reached out to Jensen but they were not much help. At best they suggested that perhaps the Crux SWRNS-63U interface was bad. They wanted me to pull the unit out and test the unit with a known good speaker. I do not have that type of testing equipment.
Does anyone here have a suggestion for me? I work at a dealership in parts and find it hard to believe that all 6 speakers can be bad. But I am open to any ideas.
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
With the new info that factory amp is still connected, Coolhand20th's original assesment may be right. Radio may be causing the noise. I would...
14
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
DarthWitten
DarthWitten
Illinois
2RZ-FE
SPLBassJunkie
    May 21, 2024
    May 20, 2024
