Stock stereo in 2010 Acadia
ReneeG
So I acquired a 2010 GMC Acadia. New motor at the cost of about $7800 or so...anyway, there is a dvd player in this stereo system. The screen is on the ceiling for rear passengers and does not work. When you put a DVD in the player, you can hear the audio, but there's no picture on the screen. There was no remote when I got the vehicle, so I thought maybe the screen was just turned off. I bought a new remote and apparently that was not the problem.
Any ideas or suggestions as to what the problem is? If I have posted this in the wrong place, please lmk and I'll delete/move it.
Renee
Check the Video cable connection.. Usually Yellow to make sure it is plugged in all the way from behind the HU in the Dash and at the Screen
Renee
Since the vehicle is 13 to 14 years old, I would consider an aftermarket DVD player with screens that fit on the back of the front seats. Finding one integrated into a head unit or having your current one repaired will be expensive, if it's not a loose cable. Good luck.
Thanks for all the great suggestions! @Ridinhi @metalheadjoe I don’t have any good pics rn but I will post up soon for sure. I’m fine with...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
389
668
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
430
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
590
ReneeG
ReneeG
huberoy123
    May 19, 2024
    May 19, 2024
