uconnect5 has an error
  • 2
Is there any issue adding a resistor to the speaker out of the uconnect?. Will that effect the Speaker level IN on the amp?
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
13K
Some circuits do have a constant draw, if there is a load that uses it, like radio settings, but it's not a battery pushing out that voltage...
790
ccuyler
ccuyler
St Augustine, FL
    May 11, 2024
RedRyder18
    May 11, 2024
