Help?
  • 2
Battery expert 2023
I have a RockfordFosgate R2 1200X1 amp that requires a 200 amp fuse plus an alpine 4 channel amp with a 40 amp fuse in it. I plan to run 0gauge wire to a block split to 4gauge. what size fuse and fuse holder do i need at the battery and what kina of distribution block do i need for both those amp?
Thank You
Thank You
I use these.work great.....i would think 200 anl would be fine on that at the battery.
106
431
402
Battery expert 2023
Battery expert 2023
Antarctica
Battery expert 2023
    May 31, 2024
    May 24, 2024
