WATER AND SPEAKERS
Raindrops naturally find their way inside your car door and wet your speakers. Is this damaging to the speakers in the short and/or long term? What can be done about it?
It does damage in the long run. The lead wires start oxidizing and can break off. A good product is a foam baffle that is basically a "cup" for the speakers. There are plastic ones as well, in case if you do not have alot of room in the cavity.
Also make sure the weep holes at the bottom of the door are clear.
It is not worth worrying about. You cannot prevent it, but it will not cause a problem as long as you own the vehicle.
Let me put it this way: My 4x4 has had the same rear speakers for 13 years, and they have seen slightly more moisture than virtually any other vehicle with speakers will ever see.
That sound reminds me of when the headphone jack or RCAs are not fully seated.
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
163
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
178
nelpastel
nelpastel
Costa Rica
huberoy123
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
