•Install Help!•
  • 5
matslp488
Hello there… newbie to the car audio world.. I’m installing a sound system on my 06 Silverado SS stock 160amp alt and battery.. It consists of 2 kicker cwrt104 dvc, kicker cxa1200.1 amp, 4 ga wiring and I also have a Rockford p400-4 amp that I want to hook up to the door speakers… this truck has an alpine ine 960 head unit and some Memphis speakers on all 4 doors… I have already connected the kicker amp, I drilled a hole to get the ground wire directly from the chassis and everything seems to work fine.. I have wired the subs at both 4 and 1 ohm and my prob is that when I give it more volume the amp goes into protection mode… anything that I’m missing???? Thicker wiring?? Is this a good combo…??? I still haven’t wired the speaker amp yet I’m trying to figure this out first… TIA
I'd check that all wire connections are tight.
Do you have a multimeter? Use one to confirm you have subs wired to correct ohm load.
I'd start there.
OP, don't bother trying to interpret this fool.
Not sure of your skill level, so going to start with the basics.
Are you sure those are 4 ohm coils? They make 2 and 4 ohm coils. You can check with a multimeter.
How did you set your gain on your amps?
That amp isn't exactly a good match for those subs.
600w x 1 @ 4ohm &
1200w x 1 @ 1 ohm.
If that was me. I would buy a multimeter if needed ($20 or less for a basic one that will do what you need). Verify the resistance on all 4 coils /ohms. Wire them up to 1 ohm, and use this to wire them around 400w (or a little above).
EDIT: ( 400w RMS for each sub. 800w x 1 @ 1ohm. )
On one or two numbers below max on your head unit. (It should give you a little room, which you can verify, but not all head units send out a clean signal at max volume. You may be getting distortion before your amp. That's a general method that as long as your head unit is rated higher, this will get you right where you want to be.
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
That or with a TB, you either have an amp, or those early 2000 years on the full size tahoe, they were wiring them in series. It's most likely...
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
That makes sense to me, I was afraid if I bypassed those and messed up setting the others I may damage my component speakers. I'll play with it...
matslp488
matslp488
McAllen TX
    May 19, 2024
    May 19, 2024
