amp in and out of power protect
masonstephens55
my ct sounds 1500w rms amp is going to power protect mode whenever it hits hard or low bass. I wired my sub ( avatar 15) to 2 ohms and it is reading 2.4 ohms on a dmm. im not sure if it is just going into power portect because it is trying to use too much power from the amp or if im doing something wrong. I dont think that the sub is blown because it is reading 2.4 ohms. help is needed feel free to ask questions thank you!
What's your voltage going into the amp at?
im on stalk alt i considered getting a big 3 kit but haven't yet
You need to be able to keep your voltage up to run it...if you're reading 9-10v at your amp now, a smart3 will go into protect that low...you need to find out why you're low before buying a bigger amp imo
as of rn i have 2 battery's. my rear is a 12v agm battery and the front is a 12v normal battery. the rear one is running 9 ish volts. im not sure if the battery is bad but its dev not getting charge. it worked for a good while.
okay im confused now, I left it connected for a while and it is now reading 13.8-14.5 volts. everything is working properly now. did something change or could it be a loose connection.
Check the resting voltage of each battery with the vehicle off...it should be around 12v...if one of the battery is under then I'd suggest getting it tested
Glad to hear it was a simple fix and the amp is working again. The 9v reading indicated it was likely a bad connection somewhere.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
Hopefully it is ok to post a "for sale" ad on here. If not, I apologize in advance. Fully serviced Earthquake PHD2 amp for sale. Asking $175...
masonstephens55
masonstephens55
Maiden NC
spokey9
    May 18, 2024
    May 18, 2024
