Amp problem?
Jake2727
CarAudio.com Newbie
I have an amp and subs in my car. The amp power light blinks and subs stop working and it goes in and out when music is played. I made sure all the connections were solid, Checked fuses. Not sure where to go from here! Any recommendations?
Right now I have 4 Gauge powering the system.
Here’s some more details on the Amp:
  • each sub handles up to 500 watts RMS
  • 2-ohm total impedance
  • mono sub amplifier (500 watts RMS at 2 ohms)
I did not install this….. Truly have no idea what i’m doing.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
653
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
697
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
295
Jake2727
CarAudio.com Newbie
Jake2727
Venice, FL
1aespinoza
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
