Running system in a diesil
PESteele
I wang on an 8 in a van
3,463
annapolis
who else is doing this
with my system turned up pretty loud i cant even hear it outside but then inside its bumpin is my car just soundproof or something or could it just be the engine noise overpowering it
flakko has a diesel I believe. his engine noise is pretty dang loud inside and out. it could be both reasons, depending on the vehicle.
You don't want it loud outside of your car..
He speaks the truth. why bother other people. they prally already hate you cause your diesels loud as ****. why piss off those old people with the bass on top of that.
When I'm bumping I can hear the drone of my flows..Its probably not as loud as your deeeeesil but i can still hear it. It doesent really bother me that much though..
I doubt that. I have never heard anyone complain about the engine noise of a diesel. I happen to like the sound of them.
Which battery did you install the amp power wire on? I am about to do an install on a Duramax.
Post is from 2006.
I searched for a thread with this topic rather than starting a new thread on the same topic.
Well honestly, there's nothing in this thread that has anything to do with your question. Not sure if you posted in the correct thread, or let it scroll down to far, and ended up in a different thread.
If you are putting two batteries in, and they are not on an isolator put it on the second battery, the one that's not to the starter.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
536
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
PESteele
PESteele
annapolis
HardofWhoring
    May 22, 2024
    May 22, 2024
