Sundown sa10 or DB machete fight MF-12R
  • 5
I understand now, so with that been said, the DB sub i posted is a good investment to replace the sundown with? If i talk about reliability and built quality.
Sure, 1500 watts RMS and a larger driver are always a good thing, right?
Assuming you are exceeding the output of your amp anyway, you may want to really move it up a notch and do a 15” like this NVX for a substantial increase in output over your existing 10. SAve yourself $50 too! ( needs a 3.5 Cu Ft box, ported, tuned to 31Hz)
https://nvx.com/collections/vc-seri...500w-rms-15-vc-series-v3-dual-2-ohm-subwoofer
I've used this driver in a couple of builds and for the money, hard to beat.
For about $160 more than you are thinking of spending on just that DB driver alone you could get the NVX 15" and a GP glue & srcew ported box tuned to 31hz. I'm sure you could fetch $160.00 for the old setup and then you would really be flexing some glass for roughly the same $$ and alittle extra elbow grease!
For about $160 more than you are thinking of spending on just that DB driver alone you could get the NVX 15" and a GP glue and scew ported box tuned to 31hz. I'm sure you could fetch $160.00 for the old setup and then you wuould really be flexing some glass for roughly the same $$ and alittle extra elbow grease!
Interesting, will think about that for sure.
Thank you guys🙂
645
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
idan167
idan167
idan167
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
