Why has my username changed to Imsoconfused? Hacked?
Disconcerting. Leaving it alone so the Admin can take a look. Unless whomever responsible starts posting a bunch of nonsense. pretty strange!
There is nothing wrong with your username. Do not attempt to adjust it. We are controlling transmission. You are about to participate in a great adventure. You are about to experience the awe and mystery which reaches from the inner mind to....
The Outer Limits.
Ha, well, have not ingested psychedelics since high school! This made me nervous, maybe I Had the update page open or something, got changed and it wasn't international. I've changed it back. If it happens again, going to buy a lottery ticket!
Yes, not sure what I did (or somebody may have done) or how that happened, soooo random! I must have had the update page open or something and maybe autofill kicked it in, not sure, kind of a stretch all the same. Changed my password nonetheless. Thanks for checking in!
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
13K
Some circuits do have a constant draw, if there is a load that uses it, like radio settings, but it's not a battery pushing out that voltage...
790
Premium Member
Current build, 2012 Mazda 3 Hatch 2.5T
Boise, ID
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
