Wirring LOC and Amp
azmandella
I am starting an upgrade to my 2023 F250 SD . I have purchased a LC5i Pro and a XDM 700/5 . I know the LOC needs direct power but could I not take it off the direct power of the AMP ? The LOC recomends a 1amp fuse in line . Well if the LOC only pulls 1 amp or less could I not take it from my 4ga wire at the amp with a inline fuse instead of running another wire direct from the battery ?
Also what does everyone recomend for tying into the speaker outputs on the back of the head unit . Taps or splice ?
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small wire used is rated for) to minimize the risk of fire if it were to short out.
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
645
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
unfortunately no empties but a couple promising choices, out of town right now have to this weekend 1) Car Radio Switch, Climate Control System...
azmandella
azmandella
Arizona
Deiimos
    May 11, 2024
RedRyder18
    May 11, 2024
