Kicker hideaway HS10 help please!!
  • 2
This_just_in88 C
Hi, I’m installing a hs10 in my 2002 f250. I currently have a Kenwood head unit. I have connected the remote wire to the head unit remote acc wire. Power to battery and nice sanded tight ground to the body under the carpet.
When I plug it in it will blink red momentarily but will not stay in. I have tried with the av cables and tapped into the speaker wires with no luck. Fuses are good. Multimeter shows power to connector. Any help is appreciated.
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring method.
Disconnect the Remote wire and put a jumper from the amp's Remote to the Power wire. See if it stays on. If not, the ground may be lacking. A zero resistance ground does not mean it will let good amperage through.
Also check if you have the Remote turn on/Signal turn on option. If yes, set it to Remote turn on.
522
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
This_just_in88 C
This_just_in88 C
florida
    May 10, 2024
3toneEYZ
    May 10, 2024
