Z Edition Class D Amplifier 2400 Watts
Hello everyone, can anyone can help me please ? i have that Z Edition Amplifier Class D 2400 Watts Max, and i would like to get its User manual, for the speakers differents wiring
here are the informations that i have ;
Power Output @ 14.4V
  • 510w x 1 rms @ 4 ohms
  • 900w x 1 rms @ 2 ohms
  • 1500w x 1 rms @ 1 ohm
  • 2400w x 1 max @ 1 ohm
But i will need the speakers wiring plan please, thanks a lot
This is pretty straight forward. These speakers inputs are summed, meaning both the + and the two - equal one +\- connection. The only reason there are two inputs for the speakers, is to make it easier to run dual wires from two subs or dual wires from a single dual vc sub. At the end of the day, whatever the total impedance is of the subs you wire using a single parallel connection or a dual connection summed parallel at the amp, it's the same.
If you can tell me which sub you intend to use (model/size. number of voice coils and the individual impedances'), I can tell you the wiring options you can use and how that impacts the amplifiers output.
Thanks a lot for your help bro, i really appreciate .
Ok i will be using a Kicker 10" CompVX 4 Ohm 600 Watts RMS
Okay, is that a dual Voice Coil? If yes, what is the ohm rating for each voice coil? Looks like it has dual 4 ohm VC's.
Ok i will be using a Kicker 10" CompVX 4 , so Ohm 600 Watts RMS
You have two wiring options - 2 ohms or 8 ohms so 2 ohms is the choice for your application.
The +/- I've added mimics the amplifiers input options. This configuration will give you 900 watts of power or 33% more than it's rated for. Be conservative when setting the gains so you don't overpower the woofer. This is the ideal setup for that amp and this driver.
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again,
Cheers
I started a thread in the general car audio forum, but wanted to asked here as well. I'm thinking about replacing the stock front speakers in my...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
  • Locked
Hello and great day to all of caraudio.com family . So I'm here looking to see if anyone may know of someone wanting to sell there steg msk 50sc...
PANSI Irwin
PANSI Irwin
Tahiti / French Polynesia
PANSI Irwin
    May 11, 2024
RedRyder18
    May 11, 2024
